44" deck fix up
Picked this one up a few weeks ago from JALLEN decent deck just needed a little TLC. It's a 44”deck that is about done now, waiting for 2 pulleys for it. Cleaned the bearings, replaced the seals, 1 bearing and 1 housing, also replaced the idler pulley bearing. Cleaned and gave it a quick rattle can paint job. It may end up under Black Jack, should be a good grass killer.
very nice!
how do the aluminum spindle housings compare to cast iron? and when did they come out? the 42" and 50" decks i just got have the aluminum spindles.
cub cadet 71 that my pop pop got new and gave me in 85......restoration just started cub cadet 100......was a friends grandfathers, given to me in 93.. restoration almost finished cub cadet 72, 150 dollar craigslist find, 38" deck, worker cub cadet 127 basketcase, my dad bought in 84 cub cadet 71 beauty (formerly johncub7172's) cub cadet 123, craigslist find |
I can't answer that one for you. I do know that the 38" deck I had on my 1210 vintage 1989 had aluminum spindle housings. I should mention they are still the same as the housings on the decks on some of the 2000 series tractors.
That looks good. I have got a 42" deck for the 128 I need to do and I should do the one on the 1711, but for some reason a deck intimidates me, but redoing a whole tractor is fine. Yeah I now, go figure. LOL
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
How do you replace the idler pulley bearing?
In my case replace the pulley, LOL.
Easy, I just drill out the spot welds with a 1/4" drill and split the two halves apart pop out the bad bearing and replace it then I bolt the two halves back together with 1/4" bolts. You can get the bearing from McMaster the bearing number on the box is FAG 6203.2RSR.C3.L38 The McMaster part number is 5972K44 the price is $6.02
That looks really good Sam! Amazing what a little paint can do!
Thanks Sam
Looks good Sam
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Thread Tools | |
Display Modes | |
