This is a lot easier to check than tearing apart the engine
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I'm going to test that today. It's been raining, and I don't have a garage yet.
have you pulled the S/G belt to verify the starter generator spins fast and quiet unloaded? it should spin very fast, get up to speed almost immediately and be virtually silent. my 106 S/G had worn out so slowly that I never noticed until the day it would not start. I replaced it and was amazed at how fast my engine started afterward.
OK, I took your advice and took spark plug out. With the starter, it sales around like it should. Does this means it the compression release not working?
Could be the exhaust tappet was adjusted with the tappet sitting on the release tab rather than off the tab.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
It was the little compression spring was off. I don't have a dial indicator so about how much should the exhaust valve be open? With the valve open I can shine flash light in the exhaust opening and see light.
I set the exhaust with the valve off the little tab. But about how far should the valve be open on the compression release? I don't have a dial indicator. I can shine light in exhaust opening and see light at valve .
