The engine leaked a good amount of oil. It originated from the valve cover. Someone had been there before since the reed valve and it's retainer were MIA. Also the cover was bent. A good used one was sourced. I replaced all the gaskets including the cam gear cover and fuel pump,and the breather filter. No more leak after an hour of run time.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Added all of the light hardware, bulbs, and grille. Also, a shot of the completed float pin.
Are those your Amazon tires?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
The tractor came with a new Carlisle tire from Tractor Supply. I purchased the other one from Amazon.
I bought a new Carlisle front tire from Amazon to match the other one the previous owner had purchased. I had the original severely dry rotted Goodyear removed and this one mounted with a new valve stem. The local tire shop had it done in less than 10 minutes.
I have a weird thing with tires. I don't care how raggedy the tractor is but it better have some decent looking non-dryrotted tires on it that properly hold air. |
New K&M seat installed:
Yeah, I prioritize that too. Easier to change tires than paint it, plus they're so much more effective.
New battery hold down strap:
Nice work
I have 2 that I am "saving".Both were local Craigslist finds. One is a 1440 and the other is a 1782. After much consideration I have decided to replace both engines (they are both n/g), with 22hp Predator engines also called the "670".
