Greg Rozar AKA- CubDieselFan
Old 01-17-2019, 07:36 PM
wjamesm wjamesm is offline
Default Looking to add rear scrape blade to 1864
Hello and looking for suggestions on this topic . I have a 1864 with a 551 snow blower and am looking to add a rear scraper blade to be able to pull snow away from the front of the garage and retaining wall along my driveway . Right now I shovel it all away far enough that I can move it with the blower , But that stinks . Lol . I would like to mount the scraper blade so I can pull all the snow away from the walls and blow it without getting off the tractor . I was looking at Xtreme's sleeve hitch and 3 point setups . I see they have a scraper blade for use with there sleeve hitch and kind of like that setup . The only thing is the hydraulic lift is being used to lift the snow blower so I was thinking of electric lift maby for the rear ? Don't know if it's been done on here or if someone has a better suggestion . Thanks
Old 01-17-2019, 07:56 PM
IHinIN IHinIN is offline
I’ve seen guys use a small winch as an electric lift.
Old 01-17-2019, 08:10 PM
RumbleFish RumbleFish is offline
I think Sam or somebody rigged up a sleeve hitch with a atv winch to lift it. Or you could do an electric actuator. I agree the single lift system is a hindrance at times!
Jeff
62 O, 1641, 1864, 1862, 1535, LT1045
#4 cart
Old 01-18-2019, 12:41 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Easy sleazy
https://www.onlycubcadets.net/forum/...ad.php?t=48391
1- 1200 in pieces
1- 1864 in pieces
Old 01-18-2019, 04:44 PM
Looks like you added a valve to direct flow to the front or rear . Did you add the hydraulic cylinders to the 3 point ?
Old 01-18-2019, 08:34 PM
Rescue11's Avatar
Both! Just a 3 port ball valve to direct flow one way or another, i.e. main lift cylinder or 3point cylinders. Pretty slick if I do say myself. Just give the lever a quarter turn flip and you have full operation of either front/mid or rear mount equipment.
1- 1200 in pieces
1- 1864 in pieces
