Greg Rozar AKA- CubDieselFan
Old 01-14-2019, 08:46 PM
Twincreek Twincreek is offline
Default Hydro Release Valves
Hi everyone. I am restoring an 882 Diesel that had been sitting a few years. I have it running but ran into an issue. With it running the hydro release valves were not leaking. Then one time I started it and both were leaking like a sieve. I took one out looked at it and put it back in. Started it up and neither was leaking. Is it possible they can stick? Can you spray them out with brake cleaner, carb cleaner, WD40 etc. or do they have to be replaced or rebuilt? Or do I have another problem?
Old 01-14-2019, 08:55 PM
CubDieselFan's Avatar
This is confusing. It does not leak when running, and does leak when the engine is cranking to start?
Is this what you mean?
If they are leaking any at all out the top then they need replacing. They can be rebuilt but I prefer to just replace them.
Old 01-14-2019, 08:58 PM
They started leaking bad while I was cranking the tractor to start it (it was cold). Once the tractor started they continued to leak. I shut off the tractor, took one out, put it back and started it again. Now no leak. It did this once before.
Old 01-14-2019, 11:33 PM
It's cold, and the small "O" rings are worn/cracked/brittle from the years of usage. they might reseal but in the end, they will need attention.
So you can have them rebuilt by the fellow on ebay, or buy new for big $$$$$$$
or wait and replace them when they start leaking again, usually at a inopportune time
your call.
Old 01-15-2019, 06:46 AM
Send them to Mark at http://www.machtechdirect.com/ problem solved.
Old 01-15-2019, 08:28 AM
Thanks Sam I didn't remember his web address, and it was past my bed time.
