Greg Rozar AKA- CubDieselFan
Old 01-11-2019, 07:17 PM
TexasP TexasP is offline
Default My First Tiller
Evening everyone. I have a #1 Tiller; my first. And after sitting down and looking it over, I have a feeling that I am missing some parts. If anyone familiar with these can tell me what I need to be able to use it, I would appreciate it.
Old 01-11-2019, 07:51 PM
Most important thing I don't see is the belt guard.
Look in the manual section for the tiller, the exploded view will tell you what all is not there.
Old 01-11-2019, 08:41 PM
I have gone through the manual and the things that caught my eye that I can't tell where they go or work on this one are the Depth Control and V Belt Tightener.
Old 01-11-2019, 09:15 PM
I make the depth adjustment handle and bolt that goes into the lift pin. The belt adjustment goes between the upper arms and the center where those arms pivot.
In the picture, it's the grey ( dull galvanized) handle and the corresponding adjustment "nut assemble" is held in with cotter pins.
I can make those for you too if you can't find used ones.
I don't have a belt guard on my tiller but I don't have kids and as a machinist, know not to put anything close to moving objects.
You will need to replace the pulley too. Those missing areas will chew up the expensive belt.
Old 01-11-2019, 09:47 PM
I was just thinking of emailing you asking if you could make those. I have seen the Depth parts on your page.
Old 01-20-2019, 12:29 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yyyep, what him says
1- 1200 in pieces
1- 1864 in pieces
Old 01-20-2019, 09:40 AM
There is a L-O-N-G and pricey belt that goes from the bottom gear box to the pto in front, that I don't see in the pix's
Old 01-20-2019, 01:13 PM
RLause's Avatar
RLause RLause is offline
I bought a belt from ebay about that same length for $17.00 a year ago. You just got to know the correct length.
https://www.ebay.com/itm/D-D-PowerDr...FTRG:rk:1:pf:0
Richard
