Cub Low Boy 154 Clutch Issue
Hello Folks,
I just picked up a sweet Cub Low Boy 154 Friday night. It has an issue with the clutch. It pops out of gear when in 1st or reverse unless the throttle is pushed way up. You cant get the tranny into gear unless the throttle is dropped way down (if that normal) and then unless you are holding the lever it pops out of gear immediately. Not an issue in 2nd or 3rd gear. I tried mowing a little Saturday afternoon (in the rain) before I put it in the barn and she did not seem to like going up hill in 2nd gear and would start to bog down..now this is my first time with an actual piece of machinery with a clutch and gears since I have a stick shift car 35 years ago. Thanks for the info~!o |
This is above my pay grade, time for Dr. J-Mech.
Hello Mr. Miller and welcome to the forum!
We do not have a section for the Lo-Boy tractors so we use the "General Talk" area. I moved your thread to the proper place. As far as the trans popping out of gear, it likely has a worn shift fork on the 1st/rev slider. Either that or the edges are wore off the sliding gear because of the clutch issue. (See below.) It is also possible that the detent on the shift shaft is not working.... You will have to take the trans apart to fix it no matter which issue it is. Not a simple job. The clutch on a 154 is on the front of the transmission. It does have a transmission brake. It's job is to stop the input shaft when the clutch pedal is depressed so that you can get it into gear quicker and without grinding. There is an adjustment procedure which is outlined in the service manual. All parts are available for the clutch. The manual can be downloaded here: http://service.mtdproducts.com/Train...-gss-1408.html For parts, I suggest these guys: http://hamiltonbobs.com/cart/search/...cub-lo-boy-mm4 Let me know if I can be any help. |
John,
Thanks for the info. I reached out to Bob before I bought the tractor. I told him that he would be my new best friend for a bit. Either way it sounds like I should take her down the road to the local mechanic shop so that it gets fixed properly and I don't spend months trying to fix it. |
The tranny itself is pretty basic and easy enough to work on but its a good half days work just to split the tractor. I had a shift fork issue in my first 154 so Ive been there and fixed that but since then the rear pressure plate broke so that 154 is now a parts donor for my second 154. They are actually pretty simple basic machines to work on.
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
I can split a 100HP tractor in a couple hours. I'd honestly rather do that than split a Lo-Boy. They just aren't as "friendly" to work on. |
Oh ya I wasnt suggesting its a job everyone can, or should do, but I think if people want to own antique tractors and actually use them they should try and learn how to work on them, and in this case it is a 'fairly' simple job once you get all the body work and wheels out of the way... which as you mentioned does require some equipment that the OP may or may not have access to.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Thread Tools | |
Display Modes | |
