Which series of mower decks will fit my 129?
I think I'm being too limiting in my searches. I've been concentrating mostly on looking for the same triangle shape that mine has. I've been told that several series of decks would fit. I suppose as long as it is compatible with the mule drive, the shape is not that big a deal (?)
We already answered this question in your other thread. And, I already sent you the info in an email several days ago.
Jon....sorry...if you did I don't recall it. Failing memory unfortunately. I just checked back through your email - you only mention that there are about 9 different models of decks that will fit, but not specifically what those models are other than the 38, 44, or 50 (A series). It would be helpful to know what other models would also work. Your suggestion was to search primarily for triangle decks, but that doesn't seem to turn up too many. I looked through both recent threads and not much was mentioned about it there.
I'm pretty sure the 38, 42 and 48 inch "triangular" decks ALL work on the 129. With a standard mule drive. The 44A and 50A will work but you need the mule drive with the tilted idler pulleys as the center spindle on those decks is off center. The 44A and 50A are "rounder" than the triangular decks.
Do pay attention, the 44C and 50C decks look identical to the A series, but have a different center spindle pulley as they were made for the 82 series tractors and use a wider belt. The C series can be converted to an A deck by replacing the center spindle pulley with an A series pulley. The decks are interchangeable in all other regards. Here's a 149 with a 50A deck and a (12hp)108 (so actually equivalent to a 128) with a 48 inch triangular deck. I think a 42 inch deck is better suited to a 108 and that's what this 108 ran for most of its life.
The "triangle" decks don't really have a model. They are just called 38", 42" and 48" or *XX" 3 spindle rotary mower* decks, but they had different year ranges made. Minor differences between all of them, and they will interchange. (They mount the same.) There are 3 different "versions" of each, so that makes 9 different decks. You WILL NOT find them listed by a "model" so stop getting hung up on a model number. Then there are the 38A, 44A and 50A decks. Like we already discussed, and like Frank noted, the "A" model decks will work, but don't get a "C" model. While they will interchange, you have to make some changes to the deck, and we don't want to get you confused. The "A" decks will work, but as Frank noted, you need the mule drive with the angled pulleys. If you don't have that style, don't worry, you can bend the ones on your current mule to angle towards the pulley, but it is important that you do that. Otherwise it will burn up belts. If you need a different mule drive, you can usually get them on ebay for about $25. |
You just might find an entire ready to mow outfit you like. I did, and there were three or four that looked pretty good. So good decks too. |
Local pickup is put in most of the ads with larger pieces. If you contact seller you might be able to ask him to "for a price" skid it and take to local fastenal to ship for you.. I have done this several times with ebay sellers. Also. Make use of the make offer option. All they can do is say no.
Call this guy.. I bet he would ship one.. Also, he was offering my choice 135$ His look to be stored indoors and pretty clean.. And he has A BUNCH of decks and other parts. Nice guy also
https://nwct.craigslist.org/grd/d/cu...627842891.html
