147 creeping
Little help please
Just picked up a 147 and when in neutral and brake locked it will creep forward. Any ideas? |
It's usually either the linkage needs ajusting or the trunion plate if frozen to the shaft. If it's real jerky when you change speed, then the trunion plate if probably froze. if it's smooth then the linkage just needs ajusting.
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Thanks I will take a look at it.
I think everything you need to know is in the Technical Library - Tractors section here.
