S/G brushes?
This might be a dumb question, but how do you access the brushes on the starter? I want to replace mine, but I cant find the things.
They're behind the rear endcover. It would be a good idea to look at the service manual before you take it apart
I read over the section on doing the brushes in the kohler manual, but there isnt much there, is there something I should be looking out for?
rebuilding generators (delco)
1) after dissasembly, check end cap berings for too much shaft slop.
2) inspect for magnet field damage inside case,integrity of all inside pieces. 3) armature where brushes ride is not groved to bad (need to turn down till smooth/even. 4) inshure where brushes are guided/ ride ,does not allow to much slop. During the 50/60's car maintenace included an occasional rebuild of generators/carburators/distributors/water pumps. Made my living as a car mechanic.owned a garage back then. if anybody can add I always learned from my good friends, still learning today,at 65yrs. old !!! GIG BIG PAC Daduke |
It's always a good idea to have the manual when you're taking something apart that you've never been into before. You probably want to inspect the bearings and commutator while you're in there, too.
Oh, I didn't mention before...make sure that the brushes you get will work on a CCW S/G. I think the brushes for the CCW ones are different from the CW S/Gs. |
