1450 PTO won't engage
I just tried to go out and snowblow by driveway. When I got out there, my tractor wouldn't start so I swapped out the battery and put the battery charger on it to help jump the tractor.
I finally got it started but now the PTO won't engage. When I flip the switch, nothing happens. The belt doesn't go around, and it looks like the clutch isn't moving on the front of the engine. I checked the fuses and they look fine. It worked when I put the snoblower on it this fall. What happened? |
Assuming your Ignition Switch is OK, then check the following:
(A) 10A Fuse (B) PTO Switch contacts between B & A (C) Wiring and Quick Disconnect Plug at the PTO Click on this to our Technical Library for the Wiring Diagram.... Diagram Click on this to our Technical Library for PTO information.... PTO
I'll start there then. Thanks
Thanks for your help. The wiring diagram and a cool head were all I needed. Apparently the wire had fallen off of the bottom of the fuse. Reattached it and all is fine.
ATA boy...........
Way to go Baja, you should be all set by the time the next snow falls. See ya at work buddy
Great news...Have to agree about the wiring diagrams on here too...
Pat Harmon Loganton,Pa 128 Cub Cadet 1200 Cub cadet (Red) LT 1042 Cub Cadet 1200 Cub Cadet 165 Hydro John Deere 1941 John Deere H 1950 David Bradley 5756 1952 David Bradley 57561 Super Power |
