Spark Plug gap.
I have two Owner's Manuals (one appears older than the other) for models K241, K301, K321, etc., engines. The newer manual specifies a spark plug gap of .035" for "battery/breakerless" systems, & the older manual specifies a gap of .025" "for gasoline." Which is correct & why the difference?
Newer breakerless and electronic systems build higher voltage,allowing for larger gap.
If you have points, run .025 , other wise go .035 if breakerless |
If you run a battery its .035 its .025 for mag.
Thanks for your help.
My 1650 has a Kohler K341-71221 16hp, 12V battery, ignition coil, and points. What do I gap at? The Kohler and Cub manuals offer different gaps when compared to one another. Their gaps are as follows:
Kohler Battery/Breakerless 0.035" Magneto 0.025" Gaseous Fuel Engines 0.018" Cub Cadet 0.025"
Just one - but thankful to have it! Cub Cadet 1650 (QuietLine Series). |
I would trust the information from an engine manual than the tractor manual.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Agreed about trusting the engine manual over Cub Cadet's.
Out of the 3 gap choices that I shared, from the Kohler manual, would I go with "Battery/Breakerless", based on the aforementioned engine setup?
yup
Thread Tools | |
Display Modes | |
