44" mower deck idler bearing
The center belt on my 44" mower deck was squealing so I removed the cover to see what the problem was. One problem i identified was that the idler pulley bearing is worn out. Does this bearing press put of the pulley or do i have to buy the assembly? Does anyone know the part number?
You will need 756-3005 Pulley, Flat Idler.
Others on here and so have I, drill out the spot welds and split it. Then you can replace the bearing and use short 1/4 x 20 bolts to re-assemble it. This bearing was a 6203RS and was cheap off of Ebay.
DSCN1729.jpg DSCN1739.jpg Yours may be made different. Post a pic up if you can.
Worked many times for me.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
Thank you for these replies. The information you provided is very helpful.
Mark the pulley halves, makes it easier to get back together, holes line up perfectly.
Most of the ones I've seen have a pilot hole in each side.
I got the deck apart.
I bought a 6203 bearing and I can see it's too big. The pulley is marked F64BI on the backside. The bearing inner race has a spacer that is proud of the bearing about 1/2". Does anyone know if there is a direct replacement bearing or should i make a spacer. |
Make a spacer. I had some that you pressed in but used them all up.
Thanks. It looks like a 6202 bearing from the measurements. Is that correct?
Thread Tools | |
Display Modes | |
