Greg Rozar AKA- CubDieselFan
Old 11-17-2021, 07:24 PM
Oldsman455 Oldsman455 is offline
Default Gt3200 doesn’t move when warm
My GT3200 Cub Cadet runs when cold. When it warms up, it doesn’t move and steering is tough. Could this be lift pump or big hydrostatic pump going bad?
Old 11-17-2021, 08:53 PM
ejl6658 ejl6658 is offline
There is a pump inside the hydrostatic transmission for movement of the tractor. There is an auxiliary pump for the hydraulic spool valves for the deck lift as well as an attachments and the power steering. Has the hydro filter been replaced recently. The wrong type of filter on the hydro can cause you issues. Is the fluid level in the hydro good?
Old 11-17-2021, 09:28 PM
Just got it home fluid looks clean and full,300 hour on the clock.
Old 11-18-2021, 06:57 AM
Can you tell by looking underneath if it has a CC hydro filter on it. You might need to remove the seat and fender pan and see how much crud has built up on the hydro. They usually get pretty dirty there after years of use and there is a fan mounted to the drive shaft driving the transmission for cooling.. Clean the hydro and make sure the fan on the driveshaft is ok. The hydro overheating would be the only explanation for the symptoms you described.
Old 11-18-2021, 02:55 PM
Farmall450's Avatar
Yes, spend the $16/17 for the CC filter and see if that helps. My 2182 manual actually showed replacing every 100 hours (if yours never has been, it's due, as you should really replace them early when new, too).
Old 11-18-2021, 07:41 PM
Just peaked underneath looks very dirty lots of dirt,grass and debris!filter is a textured black filter not a cc I don’t think.lever for front hydraulic seems to be sticking and not returning,posi traction pedal appears to be stuck as well.a shame this machine was neglected like this!it’s in good physical condition rust wise,I need to save this cub and bring it back to life!any and all of your help is appreciated!new to cc tractors,hopefully I will get a chance to dig further into it this weekend get the seat and fenders off clean it up free up the above mentioned.I will keep you all posted
Old 11-18-2021, 09:36 PM
Glad to hear you are gonna tear into it. You never know what you have to
you take a look inside. Good luck, Enjoy.
Ken
Old 11-19-2021, 12:56 PM
Farmall450's Avatar
Sounds like a FRAM, throw it away.
Old 11-19-2021, 06:27 PM
Did you check the release lever? It has to be out of the detent notch in order to work properly.
Up to 530 and counting...
Old 12-03-2021, 10:50 PM
Ken41's Avatar
Ken41 Ken41 is offline
Hey Oldsman455, Did you ever get this issue worked out.
