Greg Rozar AKA- CubDieselFan
Old 09-30-2021, 08:22 PM
Sheila468 Sheila468 is offline
Default Hydraulic transmission lever
I was wondering if anyone had any thoughts on how to fix the hydraulic transmission lever on the back of the Cub Cadet LT1045? It won't go into gear because the lever is not connecting. It seems to be broken. I took the will off, and there's a small will, where it is connected that's loose and wiggles.
Old 10-01-2021, 08:53 AM
Welcome to OCC Sheila,
it is unclear what a "will" is that you refer too.
pictures would prove helpful that we may help you further.
Old 10-02-2021, 08:26 AM
Welcome to OCC.........
Roland Bedell
Buy: Made in the USA
Old 10-02-2021, 07:54 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I am assuming that the issue being described is that, the transaxle was put into freewheel mode so that it could be pushed around, and upon attempting to re-engage the pump to the wheels, discovered that the mechanism was broke and would no longer engage?
Before you definitively say that its the issue, let start with something more simple, have you checked to see if there's fluid inside the transaxle? It definitely will not work if there's no fluid.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
