Greg Rozar AKA- CubDieselFan
Old 07-12-2018, 11:25 PM
gretschwhtfalcon gretschwhtfalcon is offline
Default Is there a model number somewhere on the deck?
Hi,
I have a parts company trying to help me with locating a deck for my 129. They asked if there is a model number somewhere on the deck. I'm thinking that if their was it is surely worn off by now. I have no idea what the actual model number is for the deck.
Old 07-12-2018, 11:43 PM
Should be a tag riveted to the top side. If it's gone, you'll have to look it up on the cub cadet website...
Old 07-13-2018, 07:00 AM
A picture would help a lot...!!
Roland Bedell
Buy: Made in the USA
Old 07-13-2018, 08:26 AM
Default deck pictures
Roland,
Since you asked....not sure how much this will help. I'll also check on the Cub website.
Old 07-13-2018, 08:32 AM
cooperino's Avatar
Originally Posted by gretschwhtfalcon View Post
Roland,
Is that not the tag I see in picture on right side as picture faces us? Can't read it from pic but looks like the tag
Old 07-13-2018, 08:37 AM
Coop...well, yeah, it is, but unfortunately if there were any numbers immediately close to it I painted over it last year when I did both sides. I don't recall seeing any numbers however - pretty sure I would not have painted over them, which is the reason I didn't want to paint over the tag to begin with. If that's where the numbers usually are, I might be out of luck. IF they'd be engraved or stamped somewhere, might be a way to still find them.
Old 07-13-2018, 08:41 AM
cooperino's Avatar
Take a close up of that tag.. You can usually make out most of the numbers.Try to clean it up.. gently tho. In any event here is what your tag likely said if its a 42 inch deck. Did you measure it?
Old 07-13-2018, 08:45 AM
Found the riveted ID tag...was staring me right in the face near the discharge!
Old 07-13-2018, 09:19 AM
Chad126's Avatar
Chad126 Chad126 is offline
Hi,
Are you needing a part for your deck or wanting a new one?
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 07-13-2018, 10:31 AM
Mine has a few areas that are rusted through. The baffles are gone at this point. It has been suggested to put new spindles, etc. in the old deck, but not sure that's the best way to go, so IF I decide to keep my Cub going (many long threads on this...too many actually!) I would want to replace the deck with one that is in much better shape.
