Roy, as atated, you are reading the diagram incorrectly. The key switch supplies all power to the related switches. The seat switch is used ONLY when the PTO is in the ON position. No other time.
Do not use "windshield silicone". The stuff for glueing windshields in is acrylic....and once it sets up, your done. You will never get that plug off again. I suggest at very least buying a $20 tarp at Walmart. Don't use silicone. |
Wow, I'm really sorry you had to go through all that with your wife.
Good luck with the Cub. You'll find it. This is the best place for help!
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
My grandfather may have rewired some stuff, but my first Cub experience was on an 1811 and when my 50# a$$ left the seat all it did was shut the PTO off. The tractor kept moving.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
I like that idea!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
The later MTD built '82 series, and on, had a PTO relay. The safety system was no longer hooked to the engine ignition. Just the PTO. Later though, they went back to the ignition style safety switches. (Not sure when they changed back. You know the machines though.... the ones you have to set the brake on before dismounting or they shut off. ) Guess too many people were falling off the machine and it would keep going.
