3205 rear issue
Pulled apart my 3205 for an oil leak and noticed some wear on the spur gear & output shaft. What would cause this? Do you see any issues if I don't change anything?
DSCN3958.jpg DSCN3967.jpg The oil was old (19 years old) so maybe that didn't help the issue either. DSCN3949.jpg Here is a peak inside an aluminum locking rear. DSCN3951.jpg
Sorry to derail Todd but your pic says Al rear. I was looking at a 3200 and it said Cast Iron. They look similar. I’ve been thinking about one of these with a smaller deck to leave at the shop instead of hauling a 2182 back and forth.
Just wondering. Sorry again for the derail.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
You have a few choices: You can flush the rear and put it back together and hope for the best. If you do that I suggest changing the oil again and looking things over inside in 50 hours or so. You can pull the rear end apart and flip the ring gear so it wears on the opposite side. I can't see what kind of shape the pinion shaft is in, and you can't flip it anyway. If nothing else, it may slow down the progression of the failure. Or.... you can replace the ring and pinion gears. That would be a sure cure, if it isn't a misalignment of the shafts. If it was mine..... I'd sell it. But the only reason I would own a 3205 is to flip anyway. I'm not impressed with them. That's a lot of metal in the rear! |
Terry, they switched to the CI rear in November of 2000. My 3205 was built on April fools day of 1999(actual build date) and has the aluminum rear.
The GT3200 is nice but I'm pretty sure it won't compare to 3 cylinder Kubota gas burner.
Thanks Jon. I only got as far as pulling the cover off the rear and didn't check the bearings or anything else yet. I was also thinking some type of alignment issue. I'll see if I can get some pics of the other gears and bearings.
I did a 3165 a few years ago and looked at those pics and the gears look new so something "ain't" right in this one.
I was talking about the pinion gear that drives the main bull gear. I think the book calls it a spur gear. The small one that drives the big one that is attached to the axles. I would call it a bull pinion gear. The last pic you posted shows it pretty good. But I still can't see if it is eroded on one side like the big gear is. Doesn't appear to be.
I think some units might have had issues with that gears mounting bolts come loose. I'd want to check them and re-loctite them. Maybe a previous owner had them come loose and retighten them before you got it. Just a thought.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder 3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller 1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers |
So user friendliness is what I’m after. I don’t want to worry about somebody damaging the 21s, they kinda are my babies.
