Greg Rozar AKA- CubDieselFan
Old 04-23-2019, 09:59 AM
neilh419 neilh419 is offline
Right, the driveshaft spins to the fan, and the fan back to trans does not. so, maybe the splines are gone eiter in the hub itself, or the shaft inside the hub, and not the trans? I've got a manual that I'll consult when I get home this evening, as well.
Old 04-23-2019, 10:47 AM
Sam Mac Sam Mac is online now
3/16" allen wrench and a 7/16" socket to remove the 4 socket head bolts at the pump end and just the allen wrench to remove the 4 bolts at the engine end. Small snap ring pliers to remove the snap ring on the end of the drive shaft and it all comes apart. BTDT many times.
Old 05-07-2019, 11:19 PM
Got back to it tonight. Indeed the splines are toast on the shaft. Can I still find one of these? Most likely need the hub, or at least the interior, as well.
Old 05-08-2019, 06:21 AM
bugeye bugeye is offline
Suggest removal of the driveshaft and measure the length. Multiple model tractors use the same driveshaft.
Check the sponsors at the top of the home page. I'll bet someone has the parts you need. Hint, there is currently one listed for sale. But, I have no experience purchasing form the vendor.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 05-08-2019, 10:12 AM
Got it off last night. It measure 21 1/4”. So looking at info. it looks like it’s 21.3”. I’ll look around at the sponsors this afternoon. I assume I need to find a used one.
You can see It’s pretty rusty. Definitely not greased. That’s my fault. I’ve only ever greased the other end.
File Type: jpg 3A056635-BB03-429C-919B-C79667BEA15A.jpg (15.6 KB, 119 views)
File Type: jpg 9C79B12F-6E0A-4C15-8D23-B80CDA5842C4.jpg (17.1 KB, 118 views)
File Type: jpg 126C2217-CA70-498E-9B37-33D5764CE553.jpg (26.6 KB, 119 views)
Old 05-08-2019, 10:36 AM
Try these guys. A 1641 or 1440 shaft are the same.
http://pattonacres.com/
https://www.cubclassics.com/
https://www.ccspecialties.org/
http://cubcadetusedparts.com/
and if they don't have on Jeff can make one for you.
https://www.onlycubcadets.net/forum/...0target=_blank
You also need a new fan.
Old 05-09-2019, 07:43 AM
Looks like you need a fan also due to the missing blade. Suggest replacing the o-ring and boots for the CV joints
Old 05-22-2019, 04:22 PM
update: Had been waiting for the mailman to show up. I found a good deal on a used driveshaft, with both joints, and rubber boots in good condition. while waiting went over the tractor, and greased and tightened up everything I could find in the manual. First time I'd ever adjusted the two bolts on the front axle, those make a big difference in steering! Put everything together, and mowed a few laps before it rained before work this morning. Running great at the moment!
Only thing is the new fan. When I tighten the bolts down, the rubber boot has enough flex that I can see the plastic on the fan stretching. I don't want to break it, and have washers in there. Do I need a washer on both sides of the fan? I also, don't want to leave the bolts too loose.
Old 05-22-2019, 06:06 PM
Jeff in PA sells a fan reinforcement plate. Problem solved.
Old 04-27-2021, 10:01 AM
I realize I'm resurrecting an old thread here. I haven't been using the 1641, as my daily driver since fall of '19. Last weekend I was out playing around with my 1641, and I'm getting a noise out of the driveshaft again, when I move lever above the halfway point. I'm afraid the splines on the shaft are bad again. The one I put on, in 2019 had good splines. I'm going to pull it, and look at it, when I get a few minutes.
Is there a chance I didn't get something back together, correctly that would cause premature wear?
