Greg Rozar AKA- CubDieselFan
Old 05-21-2019, 08:23 AM
samckitt samckitt is offline
Default JD 318 steering column same as 1872?
Can anyone confirm they are the same & interchangeable?
THanks
________________________
Scot
Old 05-21-2019, 12:01 PM
THanks
Check the mounting hole location, seems like some DEERE's had a different mount than cub, also check the column length as the steering wheel might be to high or low to the dash.
Old 05-21-2019, 11:04 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Not sure of mounting holes, but column is a ways shorter!
1- 1200 in pieces
1- 1864 in pieces
Old 05-21-2019, 11:06 PM
ccpullin ccpullin is offline
And different hydraulic line fittings.
Old 05-22-2019, 11:31 AM
Different as in fitting itself, or layout?
Scot
Old 05-22-2019, 11:54 AM
I put Deere power steering pumps( columns) to some people, in my quiet line and 82 series tractors,
they worked well and the hyd fittings were *37 flair
be aware some used pumps use "O" ring face fittings.
but these custom instillation's require special fabricated brackets and hyd lines.
both columns were a bit shorter than factory manual columns but nothing that caused a problem.
They were out of 318 Deere's
Old 05-23-2019, 07:14 AM
Leadslingingdaddy's Avatar
If the original is leaking why not just rebuild it>?
Old 05-23-2019, 07:23 AM
Don't really have time to tear into it, was looking for another option, read somewhere that they were the same. Must be the internal workings & not the overall size of it. Did some reading on rebuilding it for the leak I have & said to replace 3 seals. Looked them up & they are $51, $128, & $21 a piece.
Emailed a supplier on here for a column & they said $500. So I guess I will be rebuilding it after all.
Scot
Old 05-23-2019, 07:57 AM
cooperino's Avatar
Is the one in the 1872 an eaton? or parker? or is it something cub cadet built.
Old 05-23-2019, 08:06 AM
There is a kit for about $70 with everything one needs.
it fits them all.
Deere was the least expensive but seems someone here posted one from Messicks that was less $$.
Also there are several write ups/posts on the task.
Not hard just have to be careful and cleanliness is upmost important.
Google the 'net and /search on this OCC.
I have done several successful rebuilds, only problem is the little"Jesus" springs, as they have a habit of disappearing, and one says, "Jesus, where did it go"
My local Deere dealer keeps several sets on hand just for that reason.
Take yer time, follow the recommendations and slow & easy on reassy.
and careful on the 6 little springs ( just a bit bigger than ink pen retract springs)
Watch the valve plate orientation, make scribe marks on the outside of the sandwich case before disassy, it is all covered in the posts/net.
