Greg Rozar AKA- CubDieselFan
Old 04-14-2014, 10:19 AM
cubntn cubntn is offline
I called a local Cc dealer and he asked about the transmission belt. I checked the main belt that I can see under the seat on the pulleys to the blades.. And it was on. I have to find that transmission belt tonight and check it out.
It might explain the whirring sounds I heard that were unusual after I turned it off.
Any hints on locating this transmission belt?
Old 04-14-2014, 10:36 AM
Try this link from Cub cadet on how to replace a belt.
http://www.cubcadet.com/equipment/cu...ub-cadet-rider
Old 04-14-2014, 10:38 AM
Thanks. I've seen that belt and it's on.
He said there was a separate transmission belt on these models?
Old 04-14-2014, 10:43 AM
OOP's sorry that is the deck belt. The drive belt is up above the mower drive belt. Never did one but I've heard they are a PITA to change. It runs from the engine to the trans.
Old 04-14-2014, 10:46 AM
Ok.. Well I am going to hunt that one down tonight. I'd be a lot happier just to know it's a belt verses a bad transmission. I'd certainly never tackle that. Lol. It'll go to a repair shop either way.
This is a pic of the drive system as they call it.
Old 04-14-2014, 10:58 AM
Excellent.. Thanks.
Hopefully I can just take a light and look up under it and see if it's off.
But... If the belt is off or broken, wouldn't it still roll?
This thing won't roll... It's like the brakes are stuck.
Old 04-14-2014, 07:56 PM
SOOO000000oooooooo.......
I'm not a mechanic, but that fan sheered off something. I'm assuming thats the transmission?
#1...what is it off of.
#2...What would cause that?
#3...is it really expensive to fix???
wth...
Old 04-14-2014, 08:49 PM
Moark Willy Moark Willy is offline
It looks like the belt broke and took the fan blade off with it. Most likely something got into the belt and when it went around the pulley it broke the fan and jumped the pulley. I didn't see the belt...is it intact? At any rate you will need a new fan blade back on the rear pulley. The belt isn't the hardest thing to change and if you are mechanically inclined you can do it yourself. But expect to pay $200 if you have a dealer fix it....including parts. There are several videos showing you how to do it online, the belt, that is. The fan should be rather straightforward. But again it's up to your ability. If you wind up having it fixed have them go over everything while it's there. My Lt is 9 years old this year and I have changed the drive belt once, and the deck blade 2 or 3 times.
Old 04-14-2014, 08:57 PM
Yea, I think I see the belt in the front pulley.
wow....really..now how often would that happen to a guy??
But still. why won't it roll freely? I can turn the fan fitting (where it used to go) and it spins freely. What does this have to do with it not rolling...at all?
