54" Plow Blade
With snow weather around the corner thoughts are again to find a way to increase the up position of the plow blade on my dual hydro 1541. I was considering drilling a 3rd hole in the lift bracket on the tractor to increase the height of the lift. Just wondering if anyone has any ideas or have tried this. The reason for wanting more lift is if I get off the level driveway to tow a trailer across a lawn that has some hills, the plow digs into the turf and makes a mess of the lawn. Thanks.
You can do that or shorten the length of the Lift Rod.
You might consider adding a sleeve of 3" PVC vent pipe over the length of the blade cutting edge to prevent the blade from digging into the turf/snow. The pipe sleeve can help the leading edge of the plow float over grass and/or snow.
