Greg Rozar AKA- CubDieselFan
Old 09-10-2017, 09:11 AM
6 pin driver from MWSC??
3 pin drivers and 6 pin discs do not play well together.
I have/had them in my 1000 and 1200
Both broke w/normal use in about a year.
I'm going back to 3 pin discs, no more hot rod crap for me.
Old 09-10-2017, 09:52 AM
My 128 has a 3 pin driver and a six pin disc and its fine, why would having 3 extra holes cause an issue?
Old 09-10-2017, 11:03 AM
Don't know!!
You tell me.
2 different tractors, same result.
The 2nd one is still in the tractor, a 1000 w/M-59 shredder/chipper.It's in my storage trailer at present, cant get pic's of it.
This is the one from the 1200, it's one of my main mowers.
New OEM disc should be here in the AM.
Old 09-10-2017, 11:08 AM
Don't know!!
You tell me.
That isn't the fault of the disk.
Do your QL's have rubber mounts still? That looks like the disk was beat to death. Has nothing to do with extra holes.
Old 09-10-2017, 12:41 PM
Yes, both have new OEM style mounts and are smooth as silk, running, sounding and operating.
I DO NOT abuse my equipment if that is what you are inferring.
Somehow, I knew you would.
Furthermore, the holes that are broken out ARE NOT the ones that the 3 driver pins went through.
Old 09-10-2017, 12:52 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I am curious, is your three pin driver the QL flex type or do you have the solid older version? The flex type is imperative when using iso mounts. Surprisingly, as smoothly as the QLs run with iso mounts, when adjusted properly do move all over the place and stresses the clutch assembly and drive line. The flex plates eventually fatigue and crack. I love QLs but do realize this is an idiosyncrasy with that series.
Queen Of The Quietlines!
Old 09-10-2017, 12:55 PM
DeltaCub's Avatar
Don't know!!
You tell me.
Your broken disc appears to not have the steel lamination. I have seen this happen to old style discs years ago.
Old 09-10-2017, 01:02 PM
I do not imply things. I just say them straight out. I do not think anyone on this site could abuse their stuff more than I do. I'm pretty rough on my machines because I use them to their full potential. But I also have ran equipment for years and know how far I can push them without tearing them up. I do not think, or imply, that you are abusing the machine.
That said, see below:
This is the point I was making.
I agree that it doesn't look like it has the steel plate in the center. I too have seen the older discs with no plate that broke out.
