Greg Rozar AKA- CubDieselFan
Old 11-15-2021, 11:12 AM
05snopro440 05snopro440 is offline
Default 2182 and others Rear Taillights
After I discovered this, I searched and couldn't find any threads mentioning it. I apologize if this is a repeat, but thought I would share to try to help others.
If anyone is in search of Taillights for their 2182 or other tractors, and want ones that are accurate to stock, Cub Cadet used the rear side marker lights from a Chevy Vega (also used on other GM models). My originals had part numbers on them that I was able to trace back to that application. The plus is that if you wanted amber instead, you can just get the front side markers from a Vega as well. I was lucky to find someone local with a stash of Vega parts they were liquidating.
The only thing to be aware of is that Cub Cadet used both from the same side of the car (RH, I believe) for both lights on the tractor. If you end up with a LH and RH, you just need to remove the locating ear off the other light with tin snips to get it to install correctly.
According to CC specialties, this is the list of tractors that use those lights:
1210, 1282, 680, 1210, 1282, 680, 1512, 882, 782-Diesel, 1604, 1606, 580, 582, 1604, 1606, 580, 582,1710, 682, 682, 1711, 1712, 782, 784,1711, 1712, 782, 784,1912, 1914, 482, 982, 984, 986,1204 S/N 756,300 - 799,999 1210 S/N 756,300 - 799,999 1211 S/N 756,300 - 799,999 1340, 1440 S/N 821,060 - 880,000, 1440 S/N 880,001 - 899,000, 1535 S/N 800,000 -821,059, 1541 S/N 800,000 - 816,508,1541 S/N 816,509 - 821,059, 1572 S/N 756,300 - 799,999, 1641 S/N 821,060 - 880,000, 1641 S/N 880,001 - 899,000, 1772 S/N 756,300 - 799,999, 1782 S/N 800,000 - 821,059, 1782 S/N 821,060 - 889,000, 1806 S/N 756,300 - 799,999, 1810 S/N 756,300 - 799,999, 1811 & 1812 S/N 756,300 - 799,999,1860 S/N 800,000 - 821,059, 1861 S/N 821,060 - 836,000, 1862 S/N 800,000 - 821,059,1862 S/N 821,060 - 836,000, 1863 S/N 836,001 - 880,000, 1863 S/N 880,001 - 899,000, 1864 S/N 836,001 - 880,000, 1864 S/N 880,001 - 899,000, 1872 & 2072 S/N 756,300 - 799,999, 1882 S/N 800,000 - 821,059, 2082 S/N 800,000 - 821,059, 2082 S/N 821,060 - 836,000.2086 S/N 880,001 - 899,000, 2182 S/N 800,000 - 816,535, 2182 S/N 816,536 - 821,059, 2182 S/N 821,060 - 880,000, 2284,2084
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower
2008 RZT 54
Old 11-15-2021, 11:55 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
VERY good info. I figured this out when I was replacing one of the rear taillights on one of my 4 Cubs last year. They aren't too hard to locate on EBAY or other venues.
Old 11-15-2021, 12:00 PM
GM’s part number equivalent were:
 917153 R RH Lamp Assembly – Red
 917154 R LH Lamp Assembly – Red
Roland Bedell
Buy: Made in the USA
Old 11-15-2021, 12:04 PM
Early Chevetts used them also and you have the option of using amber if one wanted to do that.(Front fenders used amber)
But now a days they are not as plentiful as was some years back.
Used to be a day when the junk yards were full of them.
I still have a few pairs here, ---no they are not for sale
I keep them for spares for my 782's
Old 11-15-2021, 03:06 PM
89cub1810 89cub1810 is offline
The only parts of my Vega that didn't rust. Funny I kept the lights off a car I parted out and found they fit my tractor 40 years later.
Old 11-16-2021, 12:37 PM
Gary C Gary C is offline
Good information.
Old 11-16-2021, 01:39 PM
I could only find an NOS set on eBay ($$$) or a single used one for $50. Luckily I found the local ones for $10 each.
2008 RZT 54
Old 11-16-2021, 01:40 PM
I believe mine used two RH lights originally, I'd have to double check again, they're out in the garage.
2008 RZT 54
Old 11-17-2021, 11:02 PM
Farmall450's Avatar
Awesome info guys. Hopefully mine work on the new to me 2182, whenever I get the rear pan/fenders on
Old 11-19-2021, 11:58 AM
1711Cub's Avatar
Lightbulb
https://www.ebay.com/itm/17496191636...UAAOSwHkthWILa
Ouch..
