1864, starting problem.
Went to start my tractor. No power anywhere, 13.7 volts at the battery. It won't even click. Every now and then I can hear something buzzing and then and then I have power at the starter, turn the switch to start it goes click, and then no power. I even tried to jump it with power from battery positive to the main lug on starter nothing. This starting system has a relay. Any ideas/suggestions will be greatly appreicated.
Don B, USAF 1962-1968, Ft. Wayne, IN |
Check your grounds....Considering that you did a jumper to main lug on starter and it doesn't work, maybe you got a bad ground. If the ground is good, oh jeeshhh... could be starter. Another thing about the buzz you heard could be from loose connections....again check your grounds.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I would agree. Make sure the BOTH battery cables, on both ends, are clean, bright, and tight to their connections.
If you have an extra battery,
Try to see if the starter spin. Then process of elimination from there as mentioned battery cables , Both ends of the cables clean, And bolts that hold the engine to the frame are tight. . |
Finally got around to checking my 1864 no power. Found no 12v to battery spade on the ignition switch. Therefore no 12v at starter exciting spade. Ran jumper from battery pos to battery spade on the switch. Turn the start side of the ignition switch, fired right up. I have no ideas what the original problem was but at least it will start. Thank you, everyone, for your replies :
Good to hear you got it starting
does everything else work, pto, lights????
