Greg Rozar AKA- CubDieselFan
Old 11-24-2020, 05:56 PM
Originally Posted by sornstein View Post
Yes, I have the wiring diagram for the 1440. The PTO operates fine. In fact everything works once I have jump started the engine. It was just that I couldn't start the engine using the key switch. I traced the problem to no power getting to the solenoid during the start mode, thus the PTO switch. Thanks.
So when you tested with the switch on, did you get continuity between b and a, and start to b a and e?
Up to 530 and counting...
Old 11-25-2020, 10:21 AM
bugeye bugeye is offline
If your 1440 has an intermittent start issue, the addition of a relay may improve the "click" with no crank.
This was my issue on my 1864. I checked safety switches and cleaned connections. All was normal for starting for awhile, then the dreaded click, no crank. The addition of a $10 relay cured the no crank aggravation. Or at least for the past year. The relay provides full battery voltage to the starter solenoid. The solenoid coil is powered through the start circuit.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
