Lug Connections on 1440 PTO Switch
Since the actual PTO switch does not match the 1440 wiring diagram, can someone tell me which lug is what (A, B, C, D and F) on the actual switch.
Thanks. UPDATE CLARIFICATION - I have the original switch but I believe it is bad. Even though I have ordered a new one, I would like to be sure I was properly checking it with my meter. Specifically, I am wondering which lug is the 'D' lug. UPDATE #2: I believe I have properly labeled the 3 connections to the right correctly. My question is, in the picture, what are the labels of the 2 connections to the left? PTO Switch Connections.jpg |
If it is not the correct switch it prolly will not function correctly.
The correct PTO Switch for all three generations of the 1440 is 925-0893.
This has helped, thanks. I have added a picture of my switch with a detailed description of what I am trying to ascertain.
What is that switch from..?? What is the make and part number ..??
It's the original switch from a 1440. It is part #725-0893 (925-0893). See picture I have added to my original post, above. I have ordered a new switch. All I want to do is confirm that the switch is bad. In the 'Off' position, I assume I should get continuity between lugs C & D. I know which lug is C, but I don't know which lug is D. I DO NOT get continuity between C and either of the unlabeled lugs. Also, the connector that plugs onto the unlabeled lugs can be connected 'right side up' or 'right side down'.
Be sure to check the connection on the pto also. Do you have a wiring diagram for the 1440?
Yes, I have the wiring diagram for the 1440. The PTO operates fine. In fact everything works once I have jump started the engine. It was just that I couldn't start the engine using the key switch. I traced the problem to no power getting to the solenoid during the start mode, thus the PTO switch. Thanks.
