Greg Rozar AKA- CubDieselFan
Old 10-10-2020, 12:37 PM
agpmyemcnet agpmyemcnet is offline
Cool Cub Cadet GT-2186 PTO Belt
I have a 2003 gt2186 with230 hours like new condition. I have had it since new. I have the Factory installed pto belt. The problem it sometimes jumps off the bottom pulley when I first engage the pto. All bearings and pulleys are good. I have replaced the two bottom pulleys two years ago. I can install a old belt and it will stay on the pulley fine. The factory MTD is the second one that I have purchased. It seems like the belt is not exactly the same as old cub cadet belts were. If I idle the engine then sometimes it won’t jump off. I am sure that you have seen this problem before. Thanks for any help that you can give me.
Old 11-03-2020, 06:44 PM
ttt ttt ttt ttt
Old 11-03-2020, 07:03 PM
Cubcadet_107's Avatar
Originally Posted by Mike McKown View Post
ttt ttt ttt ttt
Sounds to me like there simply isn't enough tension on the drive belt. Had his issue on my old 106, all I had to do was put more tension on it by adjusting the idlers. Not sure if the 2186 has an adjustable idler or not though.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
