1A tiller replacement pulley
I have a 1A tiller, although I suspect all use the same pulley, which unfortunately at some point in it’s life it was run up against the belt guard. It is worn pretty bad and is wearing and throwing the belt. I have found old threads that suggest measuring the pulley and checking places like McMaster Carr, etc. which I have done. The problem I am seeing is the factory belt is a 13/32” x 53”, or commonly replaced by a 3v530 or 3vx530 but I can’t find a pulley in the proper size to match the belt. I can only find pulleys in a 4L or A designation in the proper size, which by my measurements is a 10” OD, 3/4” shaft, with a 3/16 key taking the 13/32” or 3V belt.
I can’t believe I am the first person looking for a replacement but who knows... somebody has to be first. So anybody have a suggestion? Can I use a pulley marked for a 4L or A belt? My research so far says no based on belt manufacture recommendations since the belt would bottom out in the pulley. Can a 4L or A belt pulley be fitted to the output shaft of the gearbox? Thanks for any help. The tiller is the primary reason for me having cub cadets and I would hate to give up on them over a pulley! |
I haven't worked on my tiller in a long time, but what is preventing you from changing the pulleys and belt for a 1/2" wide drive. The wider belt can't hurt a thing and have longer life.
