Greg Rozar AKA- CubDieselFan
Old 06-18-2019, 09:52 AM
Pbois Pbois is offline
Default 3240 mower deck issues
I took the blades off my 46” deck on my 3240 tractor to have them sharpened. Now my deck doesn’t blow the grasss out far and leaves a rod of
Grass in the middle. Prior to removing the blades it
Would shoot the grass out very quickly. The blades
Seem to the be cutting fine. Wondering what the problem may be. The blades were put back on correctly. Do they need to be timed? Or do I need new blades?
Old 06-18-2019, 11:19 AM
Post a pic of your blades.
Old 06-18-2019, 01:00 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
I had the same problem with my Snapper when I got it. Cut pretty good, but barely threw the grass out. Hi-Vac dec wouldn't "vac" much of anything up the bagger.
I sharpened the blade and put it back on as it was, still no better. Blade was pretty sharp, too. Looked closer and the cutting edge was on the back side of the blade.
You couldn't imagine the difference it made when I flipped the blade so it turns in the right direction!! Between that issue and the $12 starter solenoid, it's no wonder I got that machine for the low low price of $50.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 06-18-2019, 07:48 PM
Here I see the pic. Are u thinking that I reversed the blades?
Old 06-18-2019, 08:14 PM
Well that blade is on correctly, I'd check that the other 2 are on correctly and that the nuts that hold them on the spindles are good and tight. I have seen decks that had 1 blade upside down and a couple that the nuts were not tight. This was a 60" Haban I bought, owner said it didn't cut good, yep 1 blade upside down.
Old 06-18-2019, 08:21 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Double check that all blades wing up and are tight. Did you remove the deck? If so make sure things are back in place correctly. Did you replace any belts? You may have a belt slipping. Keep us posted what you figure out.
2-1811's
1872
2072
Old 06-18-2019, 09:21 PM
I did not remove the deck or the belt. I jacked up the front of the machine and took off all three blades. I will try and jack it up tomorrow and investigate further,
Old 06-18-2019, 10:20 PM
I believe the big spacer goes between the blade and the spindle according to the parts lookup.
Up to 530 and counting...
Old 06-19-2019, 09:00 PM
I checked under the deck and see what u mean by the large spacer. Prior to me removing the blades last week I had them done by an old school cub cadet dealer. Maybe they put them on wrong. Also, I can see each blades is at a different angle. Should they all spin at the angle?
Old 06-19-2019, 10:58 PM
I don't know that deck. But the spacer looks wrong.
2-1811's
1872
2072
