#21
Looks great. Congrats on the new machine. We can help. Now turn the hood ornament the other way.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
#22
What part of Indiana do you live? Hopefully there is someone near by that can help you keep your good looking IH Cub Cadet running I would use Kohler brand oil in your IH Cub Cadet. Todays automotive oils have a low zinc content. You need the zinc to help lube-cushion the tappets in the engine. Go to the tech section area on this site. You can find manuals for the Kohler engine and tractor service manual.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
#23
The button on the lift handle is spring loaded. It is used to lock the deck at certain heights. The clip you are missing locks the button down so the deck can float. It is described in the operators manual. The clip is no longer available from Cub Cadet. You can find them on a certain auction web site from time to time in the $20.00 range.
#24
That is a good looking tractor you have.
#25
I will be hunting for the Kohler oil today. Hopefully I will find a local spot for that. What kind of grease is recommended for the grease fittings? I didn't recall seeing that in the manual that I printed off. Also I will do my best to make sure to upload pictures as the questions come up. |
#26
Hood ornament has been turned around now, so it's correct now. I appreciate the heads up and the attention to detail. It was that way since I got it. I think my ex-stepfather took it off and did a rattle can job on the mower so he must have put it on backwards. One more thing to mark off the list...
#27
If that's a rattle can job that man deserves a pat on the back. Looks really nice. That seat is money too, did he paint the rubber?
#29
I'm really not sure I don't believe he sprayed the seat but there are a few runs in a spot or two on the tractor itself. The seat might have been sprayed as the white has some cracking maybe the paint cracked but I'm not sure!
#30
Nice looking tractor! If you have some mechanical ability, you'll be just fine working on your cub. I have a 104 and it's a pretty simple machine to work on. This site has a wealth of information too, it's helped me many times.
1968 Cub Cadet 104 |
