2182 engine quits when hot
I’ve owned Cub Cadets for years, from a 124 when I was growing up to a 782 for my own home and now a 2182. My 2182 was actually a free find, it had been stored outside for an unknown length of time and the exhaust manifold was broken. I took it home, cleaned the carburetor, replaced the main starting fuse and it started right up. After brazing the exhaust manifold on replacing the hood, grill, sides and overall cleanup, I have a very nice lawn tractor. Lately I started to sputter and quit once the engine warmed up. I thought, Bad Coil, or not getting gas and I even checked this forum for people with similar problems. Most of them said bad coil also. Fuel pump seemed to be working great, I replaced the coil. Started cutting grass and engine surged and quit after first round. So I checked the fuel flow, and only a small amount was flowing to the filter and fuel pump. So I worked my way back to the tank. These tractors have two petcock valves under the tank, one on each side bedside the inner fender. I removed both and found them completely clogged with dirt. Cleaned them out and reinstalled, and tractor runs great again. If you ever have to do this, have a couple of new rubber grommets for the valves on hand, you’ll likely tear one or both during removal. They are part #935-0149. I pulled the grommet and valve out together, if you don’t want to drain the tank, have a cork or rubber plug ready to plug the hole. After cleaning the valve, insert the grommet first and then the valve into the grommet. Thought I would put this out there since it solved my engine surging and cut off problem. Hope to keep this 2182 going for years to come, what a great lawn tractor!
First, welcome to OCC....
Next, the 2182 is not a lawn tractor. It is considered a Super Garden Tractor (SGT). It is very much capable of handling ground engaging implements. Enjoy your tractor.
Tags |
engine quits, engine surging, gas tank valves, quits when hot |
