147 Reverse Issues
I just had the rear end out of my 147 to change my driveshaft. Everything worked fine before. Now I put it back together, and when I went to take it for a ride, it wouldn’t go into reverse. The lever would go forward but not back, kind of like if I was holding the brake pedal. After I drove it for a little bit the reverse worked fine. I tried 3 times, and it would not go into reverse when I first started it. Any ideas what could be causing this? And here’s a picture because every thread needs a picture.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
From what you are describing, sounds like an linkage issue.
I was thinking the same thing, but I put everything back the same way I took it apart, and it works fine with the tractor off, and after driving for about a minute.
Is the little lever thingy that makes it roll easy engaged?
No, but could it be one of the buttons sticking? I did engage it to push it out of the garage when it would not go into reverse.
Update: I looked over everything, and saw no issues. Whatever was causing this problem seems to have fixed itself. I have been using this tractor all day with no trouble.
Thread Tools | |
Display Modes | |
