Greg Rozar AKA- CubDieselFan
Old 02-17-2019, 08:57 AM
CLW1872 CLW1872 is offline
Default 1872 with 450 snow thrower vibration issue
Hi everyone,
I was using my snow thrower this last weekend and started getting a bad vibration, I thought that gear box was the issue so I disassembled it and nothing seems wrong, gears and bearings are good. I took a closer look at the output shaft coupling and noticed rust and wear. Not sure if this is the problem, or maybe if could be the fan unit. Since these parts are no longer available, I don't know where to turn, I was looking around and found a 451 unit for $600 but really don't need the whole thing. Since gear ratio's are different. the parts i need are the same though. Any help would be great-fully appreciated.
Corey
Old 02-17-2019, 09:27 AM
Gompers Gompers is offline
Are you sure it’s the blower? And i’ll Assume you completely thawed it out before you tore into it?
I would think that any bad vibration would either have to come from the belt path or the fan path since the auger doesn’t turn fast enough to vibrate much.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 02-17-2019, 10:51 AM
Gompers,thanks for the reply, the vibration stop when i turned off the PTO, the belt has no tears, i did notice oil oozing out the pulley shaft, so thats why i assuming the shaft, fan is the issue.
Thanks Corey
Old 02-17-2019, 04:34 PM
Do you have pictures of the fan assembly?
How do your idler pulleys look?
If it was something with the auger, it would be a slower sound I’d imagine and probably not a ton of vibration.
Is it possible you burned a belt? That can cause vibration even if it “looks” ok.
Old 02-18-2019, 05:01 PM
cyclone gt cyclone gt is offline
Check the fan wheel closely. Mine got a vibration all the sudden . after I took out the wheel it had a slight bend and a nick in one of the paddles it wasn't real noticeable until it was out and you noticed it once at full rpm.
Old 02-18-2019, 06:12 PM
Thanks for the heads up, will check it closely when i can get the fan out. As for the pulley's and such everything looks good, I think since I will have it torn down, I'll replace the bearings and seals if i can find them.
Thank you for the pointers
Corey
Old 02-19-2019, 06:34 AM
After a close look the fan shaft is worn out, the splines are almost gone, when i put them together on the work bench there is allot of wiggle movement between the couplings of the output shaft and fan shaft. I found the parts so now waiting for them to arrive. thank you for putting me in the right direction.
Corey
