will a k341 fit in a 124 or 126
i am in the process of making a puller and i wanted to know if a kohler k341 will fit in a cub 124 or a 126 without major mods. thanks
You'll need to either swap the flywheel and tin for K301 parts or modify the frame to clear the larger K341. I'm working on fixing the frame on my 126 because someone hacked up the frame to fit a K321 and then someone else "tried" to fix it by welding in some patches. They didn't get the frame straight and the welds were horrible. It now has a K301 going back into it.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
that is why the 147 existed. stick a k321 with the stock flywheel in a narrow frame tractor. i guess you could make it work if you found a junked 147 frame. weld in the portion where they enlarged the frame
