Greg Rozar AKA- CubDieselFan
Old 10-12-2018, 06:55 PM
cooperino's Avatar
Tim, The outside feed is always open except for when your servicing the system. There should be an automatic bleeder and an expansion tank in the system as well.
Are you experiencing any kind of issue with the system right now?
Old 10-12-2018, 07:05 PM
Not that i am aware off. I turned it on and it raised the temp in the house to where i set in, all the pipes feel hot and i get water out of every valve i open. I was just wanting to make sure i wasn't going to damage it with my inexperience. I have a call into the company that installed it and hopefully i can get them out here next week to give it a once over and school me on it's operation.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-12-2018, 07:25 PM
I did some digging and this is a low pressure boiler, I assume that's why it has 3 pumps, one to circulate it through the boiler and one for each floor.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-12-2018, 07:54 PM
cooperino's Avatar
How many zones do you have? In other words. How many t-stats? Should be a pump for each one
Old 10-12-2018, 07:57 PM
hyperlightboards48 hyperlightboards48 is offline
Glad you got it figured out for the most part. My system was clearly much older design (house was built in the 1918) pretty cool to hear about advancement in technology. I miss the radiant heat, by far my favorite part of that house.
Tanner
Old 10-12-2018, 08:08 PM
There's two, one on the first floor and on on the second.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-12-2018, 08:09 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Tim, Do you have the hot water tank integrated with the boiler?
Plow blade
#2 Cart
QA36 snowthower
Old 10-12-2018, 08:30 PM
cooperino's Avatar
In your pic I see 2 zone pumps. Maybe 3rd I dont see is for some other dedicated circuit. Do you have any in floor radiant heat?
In the second pic you show a valve. That's pressure relief. On the taco scoop there's a self bleeder. They get corroded. Yours looks a tad corroded. Be sure that's clean so it can work. It automatically bleeds air that enters the system
Old 10-12-2018, 08:57 PM
No in floor heat. The third pump is pumping water through the boiler to a manifold which is where the other two pumps are. How do I clean the bleeder?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-12-2018, 08:58 PM
No, I have a separate nat gas water heater.
Pap's 100
Restored 108
1211 Dual Stick
1050
Thread Tools
Display Modes
