Engine starts, running poorly after 30 minutes
I have a Cub Cadet 1250 with a recently rebuilt Kohler 301 engine. The engine runs fine for about 30-35 minutes, then starts running poorly with such a loss in power that I just have to shut it down in the middle of mowing our yard. After about 45 minutes of a cool down I start it back up and finish the yard. I have replaced the ignition coil thinking it was getting hot and then causing spark issues, but the problem still exists. (I have also replaced the spark plug as well.) I do not think it is a fuel problem since this scenario has repeated itself several times: run great for 30 minutes, then runs terribly. Any ideas about what to try next?
Wouldn't rule out the fuel supply issue. All it takes is a piece of crud getting
sucked up in your fuel inlet to shut you down. When everything settles down after it sits for a while it fires up and off you go. Till it gets sucked up again. Eliminate all chances of a junk in your fuel tank which takes time and not much for money, ( maybe some new fuel line) and that variable is no longer there. Worth the effort every time. Ken |
First, welcome to OCC..........
Condenser may also act that way
Fuel vacuum could be the problem , make sure the tank is venting
Oz
My wife says I do not listen , at least I think thats what she said |
Some good ideas and I'd like to add..... too hot! Look under the tins between the fins for things blocking the winds.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Check this for blockage.
https://www.partstree.com/parts/cub-cadet-ih-109042-c1/ https://www.partstree.com/parts/cub-cadet-ih-109042-c1/ |
On one of mine I had to run an appropriate sized drill bit using my fingers to get the crud out of the inside
did not need to replace mine Quote:
Tags |
loss of power, problems after 30 minutes |
Thread Tools | |
Display Modes | |
