Well would you look at this guy, buying them two at a time!
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
It’s more fun that way, and playing Tetris to get them both on my 4’ x 10’ trailer
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
Nice pickup!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
I didn’t flush the old gas yet, it still smelled like gas in the tanks. I hooked up a battery to 123 #1 and turned the key, nothing but solenoid click. I touched the positive to the starter generator post and nothing. So looks like I have a bad starter generator on that one. The engine is free, I can turn it by hand and it has compression.
I hooked the battery up to #2 and turned the key and it cranks, also has compression. So #2 will get spark checked and carb cleaned if necessary and try to start it. Then I will swap the starter generator and see if #1 cranks and do the same.
I saw those but trying to thin out my fleet. I’d have been more inclined to get them had they had the original seats. Headlights and sleeve hitch is a good thing. Should be able to get one going in short order
-Rick IH 782 IH 126 CCC 1863 |
Wow! Two 123's when you weren't even looking. What great luck you had and for a nice price. The first hydrostatics made for cub cadets...…..glad you scored them!
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
The one that wouldn’t crank now cranks. I turned the engine over by hand a couple times and now the starter works. Maybe dirty brushes?
The other one floods gas out the carb too. Both have spark. So I think both probably will run with a little help.
Great find. You should get a least one good running tractor out of that pair.
I’ll get two. One is parts for my 102. I needed skinny front wheels and a few other odds n ends.
We have a runner! The nicer looking one of the two runs.
