Carb Swap
Hello. For those of you that have done a carburetor swap what did you do about the linkages? I purchased a
#26 off amazon that was recommended on another thread i had but the linkage for the choke is not correct? What have y'all done to correct this? Thanks By the way this is for a 100. |
Put the choke on it from your original carb.
was planning on doing just that but both screws broke trying to remove flapper room the arm. Aaargh!
So has anyone purchased an aftermarket carb that seriously was just plug and play?
They broke because they are/were staked on the thread side.
You should have filed them flush with the shaft before attempting to remove them. You are pretty much screwed now unless by some miracle you can get them unscrewed from the other side or drilled out some way. Look for a replacement carb that is junk for a new choke shaft and flapper. |
I have one..PM me. I could put one the rod and flap in an envelope.
Search the archives on this site. There is a guy who sells them and comes with both up and down choke levers.
I got one from isavetractors for my 1812.Came with both choke levers and pre set just installed and turned the key.
That's right, couldn't remember that's where I got mine, was a good deal and solved my fuel problems. If I remember right the guys in Maine.
I've taken the choke shafts on those to a buddy with a mill, and he drilled them out for me. took him like 5 mins.
