Greg Rozar AKA- CubDieselFan
Old 01-15-2019, 09:53 PM
Originally Posted by cheesedawg82 View Post
This is exactly the tech tip that I was hoping for. Thank you!!! I knew i wanted a sheet of plastic but couldn't figure out where to get it for a buck. They're calling for a big storm this weekend, I'll have to get one when I stop for milk and bread.
Where are you shopping that you could get a sheet of plastic with milk and bread? ....and how can you not buy cheese with a username like that?
Old 01-15-2019, 10:17 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
So I've been to Family Dollar, Dollar General, Dollar Tree, It's a Buck, Big Lots, Walmart, and I cannot find a roll up sled!! I have exactly 16 big rivets, best not make any mistakes.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 01-16-2019, 01:14 AM
Steve N Mi Steve N Mi is offline
This is like what we got at the dollar store but for more money. Shop around for a better price.
https://www.amazon.com/Buckmans-Ski-...965PA49YNKKDNW
Size 18 X 54.
Here is one for $3.99 but I imagine with S&H it won't be close to the dollar store deal.
http://www.thetoolworkshop.com/paric...waAiJaEALw_wcB
Oops! this last one is only 18" X 36".
Old 01-16-2019, 08:38 AM
Why not just use a piece of coil stock? It is aluminum (no rust), already in white, would last longer than plastic, and is large enough to cover the blade....not to mention a piece that size would be very cheap if you found a carpenter or maybe a roofer who had some. They would probably just give you a piece that size.
Old 01-20-2019, 06:19 PM
Made a better lift rod yesterday. Somehow the picture uploaded. I first drilled the ends of (2) 1/2" X 7 L bolts to accept cotter pins, then I welded nuts into the ends of a length of conduit. I threaded the bolts into the nuts, and tacked some washers onto the L bolts to hold it in place. I added a spring to the front of the rod between the plow bracket and the washer backing plate. Attached the other end of the spring to a bolt hole with a zip tie for now, and it works great! The lift assist especially was a huge improvement. I would definitely consider stronger thread than just a regular nut if I were to build them again. I'll leave it adjustable for now but if the threads strip out I'll probably weld it solid.
I made 2, one for the 149 and one for the 106. No spring on the hydro, and the conduit was longer.
