Greg Rozar AKA- CubDieselFan
Old 12-07-2018, 10:29 AM
RicochetFord RicochetFord is offline
Default Wide frame drag link
Is the drag link supposed to be bent to clear the frame on the spindle end? I’ve had two other wide frames at one time or another and do not remember them being bent. I don’t have them to compare to anymore.
Doesn’t seem like it would rub if it was straight but thought I would ask. Every picture I can find it looks like it’s straight as well.
Planning on removing drag link and tie rod for new heim joint install this weekend.
Old 12-07-2018, 11:38 AM
Seen lots of people mistakenly mount the drag link rod end on the spindle. Castle nut should be on the top of the spindle arm and not underneath. If the rod end gets mounted wrong, the drag link doesn’t have enough clearance in a turn or steer axle flex and gets crammed into the frame and becomes bent.
Old 12-07-2018, 01:07 PM
ironman's Avatar
ironman ironman is offline
Maybe this helps....
Old 12-07-2018, 01:51 PM
That makes sense. Will check that thanks.
Old 12-07-2018, 01:52 PM
Yes that helps, mine is bent for sure.
Old 12-08-2018, 07:07 PM
Exactly what you described is what I found. Got the rod fairy straight using a vise. Will reinstall it correctly when my new helms show up. Thanks for the help.
Old 12-09-2018, 03:04 AM
No problem, thanks for the follow up
