Greg Rozar AKA- CubDieselFan
Old 08-10-2018, 06:08 PM
Dart1917 Dart1917 is offline
The driveshaft would need to be disconnected normally but as loose as your coupler is I would think it would just come apart there unless it's hanging up on the broken pin inside. You might as well disconnect it at the engine end, as worn as that coupler is you probably need other parts to bring the whole driveshaft up to par.
Old 08-10-2018, 06:49 PM
Originally Posted by MiniXP View Post
In the middle of trying to split it now.
Followed all the steps in the Service Manual, everything seems pretty loose, but the rear end doesn't want to pull out. I realized there was no step for disconnecting the driveshaft or anything, so am wondering if that is what is holding it up. Is there a step that the manual misses that I have to do?
No, you do not need to disconnect the driveshaft. It pulls out of the engine coupler. Just make sure the coupler isn't worn and holding the pin in place. Might have to turn the engine a little if it is worn.
Here's a picture of my 107 that I just put back together this afternoon. Notice the worn notches. I'll go back at a later date and replace the coupler.
Old 08-10-2018, 06:50 PM
I'm curious why a nf tractor has tag joints in it. Every one I've ever seen had a solid coupler. Getting to old pin out will be the worst of it, you can do it from underneath but it's a pain but so is removing the rearend.
Tim, the hydros have a rag joint but the gear drives do not.
Old 08-10-2018, 07:53 PM
After looking at the video, you sheared the spirol pin ( as other folks mentioned ).
The rear coupler looks worn too. There is a center hole for the pin on the driveshaft.
I make replacement driveline parts. My rear coupler is longer and has two set screws to help reduce play. I can also make a new driveshaft and a drive hub to bolt onto the engine.
Jeff
Old 08-10-2018, 08:01 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Did you disconnect hydro and brake linkage?
I usually pull the seat pan/ fenders off all in one piece. Then it's a matter of disconnecting the rear from the frame by removing 6 bolts. Beside the linkage, I think the brush bar underneath should be removed....I'm not sure of it needs to be removed, but I always do. Just two bolts there.
I got a project this weekend or next to replace the cork gasket on my 125.
Plow blade
#2 Cart
QA36 snowthower
Old 08-10-2018, 10:20 PM
MiniXP MiniXP is offline
I checked the driveshaft connection at the motor and that is lined up so it can be pulled out and doesn't seem to be holding anything up. I actually found the old roll pin while dissembling it, so I don't think that is holding it up.
I removed the seat and fenders
Removed the 6 bolts on the side that go through the frame
disconnected the linkage to the forward/reverse lever
disconnected the brake pin.
Something still seems to be holding it up, the rear end will rotate a little and move in and out a little, but gets held up from pulling it all the way out. Maybe I'll remove the brush guard as I guess something could be catching there.
Any trick to jacking any certain part up to make it slide out easily? I have the front supported with a jack at the lift handle bar as the service manual says. Tried lifting that up and down some and didn't seem to help.
Old 08-11-2018, 09:55 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Would it be easier if you disconnected the rag joint so that the rear end assembly is no longer connected to the driveshaft . Perhaps she could get that out-of-the-way and then work on separating the coupler .
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-11-2018, 02:11 PM
Any luck getting it out?
Up to 530 and counting...
Old 08-11-2018, 05:05 PM
Yes, figured it out pretty quickly when I looked again today. I had disconnected the wrong thing when I though I was disconnecting the brake rod. Disconnected the correct thing and it slid right apart.
Cleaned everything up and I am going to wait until I get a new coupler guibo before putting it back together.
Old 08-12-2018, 09:26 AM
AndrewNoyes AndrewNoyes is offline
Lew,
I admire your bucket supports under the footrests. Simple, cheap, super stable. Very clever!
Regards,
Andy
