My "superior intellect" told me so. |
What type of solder and flux did you use? You'll need an acid flux or acid core solder. In my experience, the issue with failed solder joints is not getting the parts hot enough for the solder to flow. Also, if the crack is more than a hairline, the solder won't flow into it via capillary action, so if it's an open crack, you'll likely have trouble getting it to seal. Replace tank in that case.
I'll offer another approach. Buy a can of Red Kote from the auto parts store (I found it at O'Reilly's) and coat the interior of the tank with it. I used it on a 72 tank that was riddled with pin hole leaks. Worked great and is still holding up 4 years later. It should seal a fine crack, especially if you put a piece of tape on the outside.
nra1ifer Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631 |
Got the tank soldered today. Sealed good. Adjusted the new carb, then ran the tiller for a couple of hours. Did great!
Congrats! always feels good to fix stuff on your own.
I just want to update this thread, mainly to report on the new carb I installed. It has been very good, flawless operation after some minor adjusting......
This is where I got the carb: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Those Chinese can copy anything except business ethics!
They do work well...I've got several of 'em on my fleet.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
Thread Tools | |
Display Modes | |
