CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 07-12-2019, 07:10 PM
IHCubCadet147's Avatar
I brought my 1320 out of retirement to cut grass today. First time in over a year, it started right up, I didn’t even have to charge the battery.
File Type: jpg DF966A85-D84A-470A-B04A-BBBDF9BAA1E4.jpg (38.5 KB, 164 views)
File Type: jpg D3F1589A-BB3C-4717-8D00-B7EF437D3B8E.jpg (38.7 KB, 164 views)
Old 07-12-2019, 07:28 PM
twoton twoton is offline
Lawn looks good!
Old 07-13-2019, 09:56 AM
Looking good!
Proud owner of my Original!
Old 07-13-2019, 07:39 PM
Thanks guys!
Old 08-04-2019, 09:33 PM
risinvillain risinvillain is offline
Default what I did to my cub today
I started stripping down my 1772 today to install my three point hitch and PTO finally that I purchased on a 2072 last year. Will download pics as I am going, repainting frame, fender pan, rims, cant wait to see it completed. Stay tuned.
Old 08-05-2019, 11:13 AM
Looking forward to your pics!
Old 08-05-2019, 04:44 PM
Tony h's Avatar
Tony h Tony h is offline
Came across this... CURB SIDE late last week. CUB CADET SRC621.
It's a sort of Cub ( MTD)... I know I know it doesn't count.
Handle bar brackets were Boltless, Gear select cable (6 gears) wasn't even close to adjusted. Hasn't seen Grease probably since it was new ( 2002 era). Valves needed adjusting. AND a serious bath. A couple of hours of casual tinkering and , as a Sea Trial, I mowed 1 acre. Not sure what to do with ANOTHER spare mower but when I see these things Curbside I cannot see them heading for the crusher.
If I can't fix it , it must not be broken
Old 08-05-2019, 04:50 PM
Tony h's Avatar
Originally Posted by toyman View Post
So, I tore into the rear pto. The belts came off along with the spring. I found that the idler pulley mount bent. Where it bent on the 90* it also cracked. I ground out the crack and welded 360* around. Got it back together and the pulleys all run true and the rear pto is back up and running.
Any room for a small Gusset on the bend?
Old 08-05-2019, 06:59 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Worked on the 782D yesterday. The PTO solenoid gets hot (as does everything under the hood) and the housing of the fast-on connector that mates to the solenoid seems to relax when warm. That coupled with the lack of spring tension in the connector blades allows the solenoid to drop out after everything heat soaks.
I reseated the conductors inside the connector housing (harness end) and cleaned everything so Mister Ohm doesn't contribute to the heat and we're back to normal operation now .
Anyone know what the current draw is for the mower PTO when it's in the "hold" state? Must be a fair amount.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-05-2019, 07:01 PM
jbrewer's Avatar
Nice save Tony! Looks like it'll be good for a good long time...hardly broken in!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
