Greg Rozar AKA- CubDieselFan
Old 08-15-2021, 09:38 AM
EternalArianne EternalArianne is offline
Default Series 2000 headlights
Since my tractor was missing the lens that covers the headlights, and the OEM replacement assembly is $120, I figured I’d try to make my own!
The original doesn’t have the reflective chrome in the sockets but the new replacements do, so I was thinking some kind of reflective chrome paint in the sockets? And then get some flexible plastic sheeting and cut to make my own lens cover, then attach with either gorilla glue or tiny screws.
I was also thinking since I’m missing one fo the bulb holders, I would just wire up some plugs from a car wiring harness and use standard headlights? I mean they are 12V so they should work? Or I was thinking of straight wiring some LED lights in the sockets.
I’ll try to post my progress and pics along the way, but here’s the base assembly I’m working with…
File Type: jpeg 93FE0F5E-AF8F-4683-934B-F8E24516BA06.jpeg (30.9 KB, 143 views)
Old 08-15-2021, 05:39 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Looks interesting. Please post your progress as my 2185 needs some new headlights.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 08-16-2021, 01:41 AM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
It was only a silver/chrome reflective mylar foil used as a reflector , your local signage shop might have some in stock
Oz
Old 08-16-2021, 07:02 AM
Ok so looking at the wiring diagram, it shows the harness is supposed to have actual plugs for the headlights (like a car) and the actual MTD/CC headlight bulbs look like regular car headlights. BUT, on mine they are totally different just blade plugs and you screw in bulbs.
So I guess there were variations at the factory for the same model? I guess my idea of rewiring it with car headlight plugs/bulbs wasn’t far off lol
File Type: jpg 0F0305FF-4D21-48CB-8077-329767CD2713.jpg (14.4 KB, 131 views)
File Type: jpeg E3999499-D271-423B-A19E-DAB5D3C123C4.jpeg (19.8 KB, 131 views)
Old 08-17-2021, 07:12 AM
Progress update: trying to think of what is reflective that I have lying around, and it also heat resistant since this will be close to the engine. Aluminum Foil!
I just need to come up with a way to secure it. Super glue breaks down around 120F so that’s no good. I have some JB Weld that stuff is rated for 500F, I might dab some of that under the foil to hold it in place.
Now to cut the foil for the other side, that stuff is a pain to cut without tearing. Luckily it’s thin enough I can use household scissors and not tin snips lol
File Type: jpeg AE35FBB4-A971-46AB-817A-0510A90E3E9E.jpeg (27.0 KB, 123 views)
Old 08-17-2021, 09:37 AM
Got both sides all foiled up and glued down! Once I get the lens made and attached it will hide some of the imperfections (I hope).
File Type: jpeg 9057F509-6393-4BEB-A4B7-27DD64C6D542.jpeg (37.8 KB, 116 views)
Old 08-17-2021, 06:38 PM
You can’t really tell from the pic but I got the lenses installed. I actually had a thin plastic sheet that was the cover for an old workplace award from a place I hated, so it got sacrificed lol. I glued it down around the sides and top with the same clear JB Weld I used to hold the foil down. The bottom I left open for any moisture/bugs that find their way in to get out.
I’d say it doesn’t look too bad for not spending ANY money, just stuff I had laying around. But now comes the time to spend money. I gotta get headlights and the wiring plugs to hook into the existing harness on the tractor…
File Type: jpeg 5775E357-521B-4B36-82FE-B65A84F6923C.jpeg (37.8 KB, 115 views)
Old 08-19-2021, 06:37 PM
Another update: I did end up putting some tiny screws in the corners of the lenses in case the glue fails. Here’s what it looks like actually installed on the tractor. Next is wiring and bulbs!
File Type: jpeg F8E5ACC1-14B4-4DAA-8394-82C4897AA851.jpeg (33.6 KB, 102 views)
Old 08-20-2021, 08:43 AM
Leadslingingdaddy's Avatar
Free is always good!
Old 08-21-2021, 11:41 AM
Got the wiring all done, again free using leftover bits I had. I found another one of the OEM bulb connectors for $1 on eBay, gonna order that and some bulbs and it’ll be done!
