#121
Pulled the two axle housings. Interesting home made fix on the non-brake side. I ordered new bushings and seals. Thinking of trying to use JB weld packed in there once the new busing is in. I thought I read somewhere on here that was done with some success. This is not going to be a working tractor, just show or let the grand kids drive it around.
Thoughts? I am sure I could have it machined and get a bigger bushing also. |
#122
JB
If you super clean that area and then pack it with JB weld, it should work fine. The load is all compression and JB should work fine for that.
#123
I did. Built it up with JB weld and also used oil impregnated bushings that I drilled a hole into for the grease zerk. I hand filed the JB after it set up with a rat tail and then used some lighter Emory to get it as close/smooth as possible to hold the bushing in tight. It’s a stationary piece that doesn’t hold oil and has lasted 4 years now.
#124
Page 5 and 8
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#125
Thanks Guys, sounds like that is the way to go.
Bill |
#126
Cleaned up the housings and installed the new bushings and then packed the gaps with JB weld.
#127
Should work. I think I packed in in with a toothpick.
#128
You should be good for another 4 decades! :-)
#129
I replaced both seals. Looks like one was original (pardon the pun). It was quite a bit more robust and I had to butcher it to get it out.
#130
Jay |
Thread Tools | |
Display Modes | |
