Heres two pics of the 1650, just dropped oil . Will be pulling engine to check iso mounts and weld the stiffener bar in . Have better engine tins coming. Do hydro maint. 1 in spindles and rims to put on, any sheetmetal that is damaged will be replaced with good parts. Get up and running good for this years lawn tasks. Start restoring the 125, then the 1650 will get its turn at a full resto job to as new condition.
Dont know what I will do with the 450 sno blower attachment , have an older Ariens 824 that does the chore now. Its really all about storing the stuff, you do not want it all left outside. Will keep you guys updated as I go, thanks for your help ! Carroll |
BTW this has the alum oil pan, would it be wise to go for the cast pan ?
Which tri states are you at?
Get the CI piece and be done w/it.
Be sure to get a deep sump pan. They are on the bay all the time. |
Cub Cadet Classics usually has pans
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Im near NY , NJ , Pa border in Greenville ( Middletown), off exit 2 , I 84
Will call about the CI pan, need a really good steering wheel too ( long center arm) Thanks again for the replies fellas, great little community here. I was enamored with the CC by my Grandfather who bought a 125 new in '68 with a ton of attachments. Remember always wanting a ride with him when we visited. |
Looks like you and Lew are within a half hour of each other, I'm sure he has plenty o parts for you.
Would Lew be Darkminon 17 ? would love to talk , could use a couple of parts, not many left to get though. 125 might need some items too.
Carroll |
Yep Lew is Darkminion and got a Cub Cadet Museum!
If you decided to sale the 450 let me know.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Well, had some more time today on the exhaust elbow, they are pipe threads, used a 1 1/4 pipe thread tap to clean out a little better, then a good wire wheel on one of my slow air tools , to get better at the back. The new Kohler elbow is still the same. Only 1 and a quarter turns go on, did not force it. Bought a 1 1/4 pipe thread reducer plug with a good hex on it to turn it in . Went about 3/4 the way in with out too much grunt, so Im going to make the call that the threads are straight on the elbow,confirming with a caliper the threads touch the measuring edges the whole way as opposed to a pipe thread which as you know is tapered. Will talk to CCS and see if he has any tapered ones to replace this.
