#41
I am running out of things to do to it. Today I put new LED tail lights on it. Only things left to do is replace one headlight and get some of those grill screen fastener springey thingeys.
#42
Still have not had enough snow to try out the blower but I did chew up some snow piles and it worked good. I put the chains on, and I had kind of a fail at first when putting weight on. I found 2 ft. of 1" round bar under the welding table to stick in the sleeve hitch, welded a nut for a stop to keep it from sliding into the sleeve to far, then sild a 350 chev. block over it through the cam bore. As near as I can tell with bathroom scales it is about 145lbs. The fail part was that the hyd. didn't have enough power to lift both the 200lb. blower and the weight at the same time. Well that didn't work. What did work was I welded a piece of 2" X 16" angle to the rear of each of the 2"X2" blower push bars and bolted the block to the angle. Looks much better and will act as somewhat of counter balance to lift the blower. If I need more weight, I have a crankshaft and heads I can bolt on also. Later.
#43
Only thing missing from this thread are some pictures! Lets see this 1650!
#44
What's missing?
Beside the slot that the hydro. control lever travels is another small slot 1/12in. long with nothing in it. What's missing? |
#45
I do believe the grill on the quietline series is held on with a machine screw and nut , lockwasher,washer behind the screen , one each side, not the spring clip as on earlier models
' 68 125 '75 1650 dual stick |
#46
It's just wired on for now but I think that I will make stud bolts out of carriage bolts, slip the grill on and cap it off with a shiny stainless acorn nut.
#47
There is an adjustable stop that goes there. A little knob and a nylon stop that slides so you can set a certain speed and return to it. You can bypass it by pushing the speed control to the right and going around the stop. It's usually missing--I only have one on one of the 1450s, the other 1450 and the 1650 it's missing.
We finally got enough snow to try out the blower. All is well. Had a temporary breakdown after I shut it off for a few min. it would not start. After a little checking I found it just needed a wiggle on the PTO switch. Project 1650 complete. Mabey some paint someday. On to the next project, a 108.
#50
1650 owner
Hello everyone my first post as well thanks for being there. The cub is not sparking. Tried to take the cover off the points but had to pry the motor to get to them. Any help with knowledge will be greatly appreciated! Thank you.
Thread Tools | |
Display Modes | |
