CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 05-26-2019, 06:19 PM
Mainemann77 Mainemann77 is offline
Default Rachet Idler question
Hi y'all, newbie here again. I have a '75 1000 with the 44A deck. I've seen some conflicting sizes for the mule drive belt, one being a 1/2" x 81" belt and the other the 3/8" x 78" belt. I'm currently running the 3/8" belt however the rachet idler doesn't seem to be in the correct position. Is the idler arm supposed to sit firmly in one of the "v" notches, because mine doesn't stay in the notch. Also, I'm not sure how to tension the belt because of this. So, I'm hoping the group can come to the rescue! Thanks!
Old 05-26-2019, 06:29 PM
I believe the V notches are just an indicator as to when the belt needs to be adjusted.
Proper tension is when both idler pullies are in line with each other.
As long as they are, I would think you are good to go as long as they are not near or rubbing the axle or the front of the mule drive.
Old 05-26-2019, 06:43 PM
twoton twoton is offline
Technically, I believe that these decks use a 3/8" belt. That being said, I have always used 1/2" belts with no problems.
The model 44 deck ( larger center pulley) uses the larger 81" belt.
The model 44A deck ( smaller or 'speed up' center pulley) uses the smaller 78" belt.
In addition to what fins said, I try to make sure that the portions of the belts that go up to the PTO are as close to vertical and parallel to each other as possible.
I actually use a 1/2" x 80" belt with my model 44 deck with great results.
Old 05-27-2019, 11:46 AM
ironman's Avatar
ironman ironman is online now
Mainemann77, maybe I'm not understanding your question correctly about "staying in the "v" notches" but read here, page 8, maybe will help you.....
https://www.onlycubcadets.net/pdf/38...p%20Manual.pdf
Old 05-27-2019, 01:47 PM
The correct Mule Drive Belt for a Quietline w/ a 44A deck is: IH-59971-C1
Roland Bedell
Buy: Made in the USA
Old 05-27-2019, 03:45 PM
Thanks everyone! Greatly appreciate the info!
Old 09-14-2019, 05:36 PM
Hey Roland, do you know the size of this belt for the part number you listed?
