Greg Rozar AKA- CubDieselFan
Old 01-03-2019, 11:23 AM
AL Farmall Boy AL Farmall Boy is offline
Default Flat, Semi, or Gloss Black on a Cub Cadet 1450 Resto. ?
I am in the middle of restoring a Cub Cadet 1450 Quietline and am planning the painting stages and colors of each part. I am trying to determine which type of black will look the best on all parts to give the best "clean" appearance. I will be mixing the paint with a hardener (I have proper PPE) and a reducer, so this is not rattle can. I have been searching for pictures to compare but I really haven't found much.
(1)
So far I have the following list of parts to be painted black. Please let me know if something has been omitted or if there is a part you think would look better black. I realize they painted them all together at the factory, and I want to clean the look up a little and be more detailed.
  • Gas Tank Brackets
  • Muffler Box
  • Engine
  • Foot Tread Pads
  • Aluminum Dash Tin (cut & apply decals to lettered areas and mask unpainted aluminum areas)
  • Upper & Lower Grille Screens
  • Rear of Seat Pan
  • Hood Hinge
  • Drive Shaft
(2)
Also, either on each part or overall together; which shade of black do you think will look the best? Flat Black, Semi-gloss Black, or Gloss Black?
Old 01-03-2019, 01:34 PM
I used "Satin" black on my 1450.
Roland Bedell
Buy: Made in the USA
Old 01-03-2019, 02:02 PM
Is that more of a semi-gloss? Do you have any pictures of the various parts you could share?
Old 01-03-2019, 03:00 PM
Yes, Satin is like a semi-gloss. Tractor tucked away for the winter. Won't dig it out now until April.
Roland Bedell
Old 01-04-2019, 10:14 AM
I think I will go with a Semi-gloss black on all parts to be painted black.
The big question is......what about that aluminum dash tin? I want to restore it similar to others where they polish, mask, paint, and apply decals to the lettered areas. Should I go with Semi-gloss black on that or gloss black?
I just want it to "pop" and look as nice as possible since I'm going to the trouble anyways.
